Baofeng UV-3R -(Mark II) Upgarde -VHF 136-174Mhz -UHF 400-470Mhz -Dual Freq Display
UV-3R Mark 2 Quick Start Guide
https://www.youtube.com/watch?feature=player_embedded&v=t9DRmv77AagUV-3R+ Plus comparison
https://www.youtube.com/watch?v=ZefTr0dKArkBAOFENG UV-3R The transceiver is a micro-miniature multiband
FM transceiver with extensive receive frequency coverage,
providing local-area two-way amateur communications along with unmatched monitoring capability
VHF/ UHF DUAL-BAND TWO WAY RADIO
-Frequency Range: 136-174 / 400-470MHz
-Dual-Band Display, Dual Freq. Display, Dual-Standby
-Output Power: 2 Watts
-99 Channels + 1 Emergency Channel
-50 CTCSS and 104 CDCSS
-Built-in VOX Function
-1750Hz Brust Tone
-FM Radio (87.0MHz-108.0MHz)
-LED Flashlight
-Large LCD Display
-Hight /Low Power Switchable
-25KHz/12.5KHz Switchable
-Emergency Alert
-Low Battery Alert
-Battery Saver
-Time-out Timer
-Keypad Lock
-Monitor Channel
-Channel Step: 5/6.25/12.5/25KHz
Specifications :-Frequency Range :VHF136-174 UHF 400-470MHz (Dual Band)
-Operating Voltage :3.7V
Operating Temperature: -30c~+60c
Battery: (Li-ion)
Antenna Impedance: 50 ohm
Dimension(without antenna&battery(L×W×H): 47*81*23(mm)
Weight(with antenna&battery): about 130g
Transmitter: RF Power Output UHF:2W/
FM Noise: 65dB
Adjacent Channel Power: 45dB/42dB
Receiver: Spurious response rejection 60dB
Receiver current: 400mA
Standby Current: 75mA
