Casio Protrek 110T 7V สายไทเทเนี่ยม 6,000
ประกัน CMG
Tel 0900033738
Line Wiccaner
นัดรับได้ที่ ฐานทัพอากาศดอนเมือง
Mineral Glass
100-meter water resistance
Case / bezel material: Resin / Aluminum
Double-lock, 1-press, 3-fold Clasp
Titanium Band
Solid Band
Electro-luminescent backlight
Full auto EL light, afterglow
Solar powered
Digital compass
Measures and displays direction as one of 16 points
Measuring range: 0° to 359 °
Measuring unit: 1 °
20 seconds continuous measurement
Graphic direction pointer
Bidirectional calibration and northerly calibration function
Magnetic declination correction
Bearing memory
Altimeter
Measuring range: -700 to 10,000 m (-2,300 to 32,800 ft.)
Measuring unit: 5 m (20 ft.)
Auto memory measurements
(up to 40 records, each including altitude, month, date, time)
High Altitude / Low Altitude Memory
Cumulative Ascent / Descent Memory
Total Ascent / Descent Memory
Altitude differential
Others: Reference altitude setting, Altitude graph
4 display formats, Altitude measurment type (0'05'' or 2'00'')
*Changeover between meters (m) and feet (ft)
Barometer
Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
Display unit: 1 hPa (0.05 inHg)
Atmospheric pressure graph
Atmospheric pressure differential graphic
*Changeover between hPa and inHg
Thermometer
Display range: -10 to 60 °C (14 to 140 °F)
Display unit: 0.1 °C (0.2 °F)
*Changeover between Celsius (°C) and Fahrenheit (°F)
World time
29 time zones (30 cities), city code display, daylight saving on/off
1/100-second stopwatch
Measuring capacity: 23:59'59.99''
Measuring modes: Elapsed time, split time, 1st-2nd place times
Countdown timer
Measuring unit: 1 second
Countdown range: 24 hours
Countdown start time setting range: 1 minute to 24 hours (1-hour increments and 1-minute increments)
Daily alarms
5 independent daily alarms
Hourly time signal
Battery level indicator
Power Saving (Display goes blank to save power when the watch is left in the dark.)
Full auto-calendar (to year 2099)
12/24-hour format
Button operation tone on/off
Regular timekeeping: Hour, minute, second, pm, year, month, date, day
Accuracy: ±20 seconds per month
Approx. battery operating time:
6 months on rechargeable battery (operation period with normal use without exposure to light after charge)
20 months on rechargeable battery (operation period when stored in total darkness with the power save function on after full charge)
Size of case: 56.9 × 47.4 × 11.5 mm
Total weight: 96 g
EL:Blue Green
