_ ลดราคา HURACAN HR-07+ HF/CB กำลังส่ง 50W 320CH เปิดแบนด์ตรงกับช่องไทยทุกแบนด์
ขาย HURACAN HR-07+ HF/CB เปิดแบนด์ให้ตรงกับช่องไทยทุกแบนด์ Huracan 320CH มากสุด กำลัง 50W
ของใหม่ อุปกรณ์ครบ ตัวเครื่อง ขาตั้ง ไมค์โครโฟน สาย dc ครบชดยกกล่อง
Huracan HR-07-NZ 10/12 Meter Mobile 50 watt Mobile
GENERAL SPECIFICATIONS
C.p.u controlled 28-29.700 Mhz ( 24.5-29.999 MHz export )
50 Watts RF Output Power Dual Finals(IRF520 Mosfets) with fan cooling
Extra Large, Backlit Meter Changes Colour Tx (red) / Rx (blue)
Variable Power Output .
AM / FM / USB / LSB / PA Modes
6 Digit Frequency Counter (100hz resolution)
Selectable New Zealand 40 channel cb radio band from front panel
Front panel mounted microphone socket
Back Lit Display & Meter with Dimmer
Selectable I.F receive filter narrow or wide (any mode)
6 Digit Counter and Channel Display (blue)
RF/squelch Gain and Microphone Gain Controls
1.5 khz fine Clarifier Tx/Rx
High Gain 5 Element Noise Blanker (NB and Automatic Noise Limiter (ANL)
TURBO Echo - with variable delay
MONI - All Mode Talk-Back with Volume Control
Roger Beep with On/Off Control
Designed By David and Mike along with the engineers and marketed later that year by David and Mike of Yeti Communications Ltd (NZ) designed by Amatuer operators for the dx market with some new ideas and alot of thought in to functionality .However a change in production at the factory meant the transceiver only was made for one run of 50 units before production of the model was stopped in favor of smt style production .There has never been a MKII of this radio put into production despite rumours on the internet to this date (may 2016)
This has to be in the top 5 of rarest cb radios ever made due to the extremely low quantity made and short production run
Below is the original write up of the features the transceiver has which many sites have copied over the years .
The radio offers just about every feature you could ask for and retains the excellent modulation and echo of it's predecessors.
Standard frequency range is 28 - 29.700MHz. 8 bands in 5khz steps
Export frequency coverage is 24.500-29.995 MHz 8 bands in 5khz steps
****Plus New Zealand CB Radio 40 channels as a extra switchable band with channel readout ****
New and exclusive to
www.yeticomnz.com is the Yeticom Huracan HR-07-NZ.
Fully redesigned and improved on with new coverage ..internal temp controlled fan .switchable wide/narrow filter...designed by New Zealanders and made in China to meet the demands of the modern day ham radio operator .
Fm mode now has per and de-emphasis in the audio chain for far better fm mode operation for the European market
The receive has a new design to remove imaging problems pervious models had. Also we had had the manufacturer improve the if filter and if filter stages for lower if noise
Also added to the design is a switchable 10.695 MHZ I.F Filter (narrow/normal)
Extra cooling has been provided for the hotter climates ..the cooling is provided by a temperature controlled fan internally cooling the finals and heat sink.
The mother board is a completely revamped design .
What's in this package?
- Mobile bracket with screws
- Microphone
- DC cable
- Replacement fuse
Certificate CE,ROHS
ซื้อมาหมื่นกว่าบาท ขายเพียง 9500฿ พร้อมส่ง ems ฟรีทั่วไทย
สนใจโทร 0869455977
หรือทักไลน์ไอดี ctek.thai
