ขาย500บาท เป็นของใหม่คับตอนที่ซื้อ ซื้อมาผิดรุ่นคับ พร้อมส่งEMS แถม cpu 1ตัว(cpu ไม่แน่ใจไช้ได้หรือป่าว)
1=Supports processors
- Supports Intel Tualatin PIII/Celeron with 100/133 MHz bus speed
- Supports Intel Coppermine PIII with 100/133 MHz bus speed (highest supports 1.13 GHz)
- Supports Intel Coppermine Celeron with 66/100 MHz bus speed (highest supports 950 MGz)
- Supports Intel Celeron Processors at 266/300/333/366/400/433 MHz with 66 MHz bus speed
2=Supports FSB
- Supports 66/100 MHz Frequency ()Intel 810/810DC100/810E)
- Supports 133 MHz Frequency ()Intel 810/810DC100)
- Supports 133 MHz Frequency ()Intel 810E)
3=System memory
- Provides two 168 pin 3.3V unbuffered DIMM sockets.
- Supports 64-bit wide DIMM modules with 100MHz SDRAM devices
- Max supports 512MB SDRAM
4=Onchip AGP
Integrated 2D/3D Graphics Controller
Integrated H/W Motion Compensation Engine
BIOS
- Plug and play ready Supports ACPI
5=Onboard IDE
- Supports two PCI PIO and Bus Master IDE ports
- Two fast IDE interfaces supporting four IDE devices including IDE hard disks and CD-Rom drives
- Supports up to PIO Mode 4 timming
7=Supports "Ultra ATA/66" Synchronous DMA modes, transferring data up to 66 MB/s
Onboard I/O
- Winbond W83627HF LPC I/O chip
- One floppy port supporting up to two 3.5" of 5.25" floppy drives with 360K/720K/1.2M/1.44M/2.88M format
- Two high speed 16550 compatible UART (COM1/COM2/COM3/COM4 selective) with 16-byte send/receive FIFOs
- USB host interface supporting 2 USB ports
- One joystrick port
- Infrared interface
- All I/O ports can be enabled/disabled in the BIOS setup
8=Onbosrd Sound
- Intel AC' 97 2.1 Specification Compliant
- 16 bit stereo codec
- Multiple stereo input mixer
9=Mono and stereo volume control
Provides onboard Line-in Jack, Microphone-in-Jack, Speaher-out Jack and MIDI/Joystrick Connector
Expansion : 3 X PCI
042850101
0854515415 HS4JBM
suchart0(แอท)hotmail.com
ธ.กรุงเทพ สะสมทรัพย์ 416-0-60663-0 สาขา วังสะพุง
ชื่อบัญชี สุชาติ ก้อนทอง
