เพิ่มของใหม่ค่ะ
M3C4 XM-L ตัวแรงวสำหรับส่องไกลๆ(เทียบกับTK35 แล้ว แรงเท่ากัน แต่ตัวนี้สามารถรวมแสงให้สปอตเข้มได้มากกว่านะคะ
Specifications
Model EagleTac M3C4 XM-L LED Flashlight
Max Output Power 748 Lumen with 39,840 Lux at 1 meter
Continuous Runtime Turbo - 748 ANSI lumen (1.5 hours)
High - 404 ANSI lumen, (3.5 hours)
Med - 192 ANSI lumen, (8 hours)
Low- 65 ANSI lumen, (28 hours)
Very low - 5 ANSI lumen (100+ hours)
Operation/Functions Dial the ring to turn the flashlight on/off, adjust between the five brightness levels, and access the three hidden modes (strobe, fast beacon, SOS). To access the hidden blinking modes, turn the ring from the turbo mode to the off/standby mode, then back to the turbo mode within 2 seconds to cycle through the hidden modes.
Lamp Type CREE XM-L T6 LED
Reflector Smooth for max throw
Battery type 2 - 18650 rechargeable or 4 - CR123A primary
Housing Material Aircraft Grade Auminum
Body diameter 1.5 inches (4cm)
Bezel diameter 2.4 inches (6.2cm)
Length 6.5 inches (16.5cm)
Weight 12.5 ounces (excluding battery) (356gram)
Finish Hard Anodize HAIII finish in black
Water Proof Yes - IPX8
Anti Roll Yes
Beam Characteristics Good Balance of Throw and Flood with good side spill for close up
ราคา 4450 บาทรวมส่งค่ะ
