เวอร์2.1 ใช้กับ GPS ตัวนี้ไม่ได้ แต่ 2.0A ใช้ได้ครับ วิเคราะห์ให้ด้วยครับ
Very simple, direct that ttl-level output, NMEA0183 standard data
Factory set to 4800BPS
Use Sirf IIe chip, is 30-60 seconds cold start, we generally about 30 seconds outdoor tests can be completed the first orientation
12 parallel channel! Although no SIRF III formidable, but the real practical use, no major difference!!
Ultra-low power, small size, only 43 mm (L) x 43mm (W) x 14.5 mm (H) (module board only)
Built-in rechargeable battery for memory ephemeris, RTC backup, and TTFF
Output version V2.2 NMEA0183
Enhanced processing operation to provide accurate city, canyons, forests positioning effect
Suitable for car navigation, marine navigation channels, air location, personal navigation and tracking systems, mapping ... ...
Specifications:
Location Accuracy: Position: 2 meters without S / A
Acceleration: 0.1 m / sec without SA code
Time: 1 microsecond
Positioning time: Cold start: 40 seconds (average)
Warm start: 33 seconds (average)
Hot start: 2 seconds (fastest)
Signal Sensitivity: Tracking: -152 dBm
Dynamic conditions: Altitude: maximum 18,000 m
Speed: Maximum 500 m / s
Acceleration: 4g fastest
Refresh rate: per second
Coordinate System: WGS 84
Power consumption: DC 5V normal (tracking): 380 mW
Operating temperature: -40 ° ~ +85 ° C
Storage Temperature: -55 ° ~ +100 ° C
Operating humidity: 5% to 95% non-condensing conditions
Pinout:
SIRF IIe Taiwan
Factory Setting : TTL DATA LEVEL 4800bPS
RED=============== 5V + (Stable voltage power source)
BLACK==============GND -
YELLOW============GPS TX (NMEA DATA OUT to PC or device)
WHITE=============GPS RX (NMRA DATA IN for setting)
